Internet not working on HUAWEI ASCEND g6-u10
elduffio6
I am having trouble with my 48 internet... have applied the correct internet settings on my phone but I am still getting no data even tho I have 'the don' membership...how do i get it working?
*edited title to match conversation* - Sheena
Try the online Tweakker configurator first - if that works then that's great - you're done!
If your specific phone model is not listed then try choosing one that is "similar" as that may also work.
If, as happens to many people including me, it does not work (e.g. never sends any configuration settings to your phone) then you will need to configure the settings manually so read on...
Make sure that your membership is active and you actually do have a data allowance through your membership or a data add-on.
  • MMS Proxy: 10.1.11.19
  • MMS Port: 8080
  • MCC: 272
  • MNC: 11
  • APN Type: default,mms,supl
If that APN Type doesn't work then try:
  • APN Type: *
Make sure that data is enabled.
If you configure these settings and they still don't work then please DOUBLE CHECK that you did not make any mistakes - e.g. some people have mistakenly entered 48.months.liffeytelecom.com instead of 48months.liffeytelecom.com etc. The settings must be entered EXACTLY as specified above.
If you already have internet/APN settings but they are different to those above then reconfigure your settings so they match those above or delete any existing APNs and start again and add the 48 one anew.
If internet/data still does not work after configuring the settings correctly then try powering off and on again and maybe manually scanning for networks and connecting to 48.
How do I add/configure an APN on my phone?
You need to check the documentation and user interface for your phone for specific instructions.
However on most Android phones the process is similar although there may be slight differences how to navigate the menu options to get to the right place and slight differences in the options that can be configured.
See here for an example of a general guide for Android phones:
Similarly for iOS the specific menus/options may differ depending on the phone and version of iOS. But this is what Apple have to say about it:
And here is another third party guide (which may or may not be for a specific version of iOS):
If necessary search the web for specific instructions for your phone.
A note about personal hotspot setup on iPhones
Once you have your internet APN set up and data/internet access working you can also use this connection as part of a personal hotspot (this will probably use up your data allowance more quickly than "normal" internet access so keep an eye on your quota and that you don't breach the fair usage limits).
This is generally straightforward on Android but Apple sometimes make it more difficult on some iPhones/iOS versions for some reason...
Some people find that their iPhone/iOS iOS 8?) does not show the personal hotspot option in which case the following workaround may be required:
But note:
  1. At around 1 minute into that video he has Personal Hotspot > APN = gadget. Enter 48months.liffeytelecom.com instead.
  2. At around 2 minutes into that video he has Mobile Data > APN = internet and also Personal Hotspot > APN = internet. Enter 48months.liffeytelecom.com instead.
A note about 4G dongles/routers
If you're using a 4G dongle/router rather than a phone then you'll need to refer to the device's user manual for instructions on how to configure its APN/internet settings (and maybe SIM PIN unless you disable this in a phone first). Most or all such devices run a small web server that provides the management interface and which you connect to using your web browser.
95 REPLIES 95
no working for Lenovo K5
Follow the instructions here:
Thank you so much.  I'm not technically minded and it took a bit of searching through the settings.  I followed your instructions step by step and I'm now sorted
Glad it helped.
Some of the instructions elsewhere are not 100% correct but these ones have never failed:
http://community.48months.ie/t5/Other-Help/Internet-not-working-on-HUAWEI-ASCEND-g6-u10/m-p/34493#M1...
thanks a gazillion ,  worked a treat. I am a non tech Luddite so very simple instructions much appreciated !
Can you please help me? In France have an iPhone X s max  and my mobile data is not working  it has no service or is searching. Last time I was in France it worked about 2 months ago. I have balance/credit and have followed all the apn instructions Multiple times but it is not working when I enter different setting for MMSC and MMS Proxy they disappear straight away , last time it worked perfectly ? Please help thanks
Unfortunately loads of people have been having problems with data or even basic connectivity while roaming abroad lately. But I haven't seen any single failsafe fix for this where it happens. There are many recent threads about this situation in which you might find stuff to try but some people never got it working. Other than that all I can suggest is that you contact 48 support but, again, some people tried that and got nowhere...  😞
Hi,
I'm having a similar issue.. .I deleted all APN trying to solve another issue (roaming not working). Now back home I'm trying to add the APN details exactly as you have advised but the details disappear as soon as I hit "save". The APN is not saving.  I had also tried the  APN Type: * but still not saving.
I´m unable to receive calls/Texts or use data... I can't register on the 48 network either I get "unable to connect.try later" when trying to do so...
I can't contact anybody on 48 either as they seem to have removed the messaging service.
