Problem moving number
AlanC3282
my number keeps getting rejected by sky to keep with 48
You'll need to explain your issue more clearly.
What exactly are you trying to do here?
Port your number from Sky to 48, or from 48 to Sky, or something else?
What steps are you taking to do this, what goes wrong, do you get any error messages, etc.?
If you're having problems porting your number from Sky to 48 then you might need to contact Sky support for assistance.
You might also want to review the number porting instructions:
