Internet not working on HUAWEI ASCEND g6-u10
elduffio6
I am having trouble with my 48 internet... have applied the correct internet settings on my phone but I am still getting no data even tho I have 'the don' membership...how do i get it working?
*edited title to match conversation* - Sheena
Try the online Tweakker configurator first - if that works then that's great - you're done!
If your specific phone model is not listed then try choosing one that is "similar" as that may also work.
If, as happens to many people including me, it does not work (e.g. never sends any configuration settings to your phone) then you will need to configure the settings manually so read on...
Make sure that your membership is active and you actually do have a data allowance through your membership or a data add-on.
  • MMS Proxy: 10.1.11.19
  • MMS Port: 8080
  • MCC: 272
  • MNC: 11
  • APN Type: default,mms,supl
If that APN Type doesn't work then try:
  • APN Type: *
Make sure that data is enabled.
If you configure these settings and they still don't work then please DOUBLE CHECK that you did not make any mistakes - e.g. some people have mistakenly entered 48.months.liffeytelecom.com instead of 48months.liffeytelecom.com etc. The settings must be entered EXACTLY as specified above.
If you already have internet/APN settings but they are different to those above then reconfigure your settings so they match those above or delete any existing APNs and start again and add the 48 one anew.
If internet/data still does not work after configuring the settings correctly then try powering off and on again and maybe manually scanning for networks and connecting to 48.
How do I add/configure an APN on my phone?
You need to check the documentation and user interface for your phone for specific instructions.
However on most Android phones the process is similar although there may be slight differences how to navigate the menu options to get to the right place and slight differences in the options that can be configured.
See here for an example of a general guide for Android phones:
Similarly for iOS the specific menus/options may differ depending on the phone and version of iOS. But this is what Apple have to say about it:
And here is another third party guide (which may or may not be for a specific version of iOS):
If necessary search the web for specific instructions for your phone.
A note about personal hotspot setup on iPhones
Once you have your internet APN set up and data/internet access working you can also use this connection as part of a personal hotspot (this will probably use up your data allowance more quickly than "normal" internet access so keep an eye on your quota and that you don't breach the fair usage limits).
This is generally straightforward on Android but Apple sometimes make it more difficult on some iPhones/iOS versions for some reason...
Some people find that their iPhone/iOS iOS 8?) does not show the personal hotspot option in which case the following workaround may be required:
But note:
  1. At around 1 minute into that video he has Personal Hotspot > APN = gadget. Enter 48months.liffeytelecom.com instead.
  2. At around 2 minutes into that video he has Mobile Data > APN = internet and also Personal Hotspot > APN = internet. Enter 48months.liffeytelecom.com instead.
A note about 4G dongles/routers
If you're using a 4G dongle/router rather than a phone then you'll need to refer to the device's user manual for instructions on how to configure its APN/internet settings (and maybe SIM PIN unless you disable this in a phone first). Most or all such devices run a small web server that provides the management interface and which you connect to using your web browser.
96 REPLIES 96
Itsworking now thank you
Great thanks, working at last.
Thanks. No change. When I search mobile networks 48 is listed but still won't connect.
I don't understand - above you're saying that you cannot connect at all but here you're saying that calls/texts work!?
http://community.48months.ie/t5/Need-Help/Internet-not-working/m-p/39920#M16320
Any update?
No. Still the same. As I said, I can receive and make calls and texts but can't connect to the internet via 48.
If you followed the instructions that I linked to and your data/internet connection still does not work then almost certainly you still have something configured wrong.
Especially if everything else (incoming/outgoing calls and texts) is working fine.
If you can't/won't post screenshots of all of the relevant settings for review then all I can suggest is that you contact 48 support and maybe they can help you:
Ok, I finally got the screen shot. Had to do it in two sections. Where do I send it to. Bearing in mind it is on my phone and I will be using wifi.
You need to post it here.
You can attach/embed pictures in posts using the message editor toolbar.
Also what does *100*8# return?
Is data enabled and is data roaming enabled?
Is the APN correctly configured and selected for use?
