Internet Settings for Motorola Defy+ not working
Motorola Defy+ is doing nothing, even with Data Roaming on and the generic settings put in
Have you tried using the Tweakker APN app that I mentioned above to configure your phone for internet access?
If that doesn't work and manually configuring it doesn't seem to work then you might need to log a support request to get 48 to look into this for you:
