I've a blackberry 9360 and I realy havnt a clue how to get the internet settings working?
Hello I've a blackberry 9360 just got it and I tried using the internet settings information provided nd I put the web adress into the ip thing I think but its still not working could someone tell me where ta go to put the settings and what settings to put in please?
Did you try the online configurator?
http://48months.tweakker.com/choose/BlackBerry/Curve%209360
Did that work?
If not then have a look at this:
http://community.48months.ie/t5/Need-Help/Blackberry-Legacy-Guide/m-p/148#U148
Do you have a data allowances as part of your membership or add-on?
Your online account should clarify if in doubt.
Did that work?
