went over fair usage
for some reason it won't let me do anything with my phone, it keeps saying 'call barring' is on when i try to call someone even though it's not, how do i fix this?
If you breached the fair usage limit and got barred then you are barred from all services for the remainder of your current membership month.
When that expires you can contact 48 support and get the ban lifted.
By the way a second ban is for good.
