I have only joined 48 have membership i cant send calls or texts but I can recieve calls and texts?
skully
@skully wrote:
I have membership "guido" 2 acctualy until the end of febuary
What is the actual expiry date?
Did outgoing calls and texts work before this?
If so and it stopped then any chance you breached the fair usage limits and got barred for the remainder of your current membership month?
If not then as mentioned above log a support query to get 48 support to look into this for you.
6 REPLIES 6
Hi skully
Can you check your account and relay the details/status of your membership.
I'll wait as you do.
skully
Hi skully
Log a support request using my link below.
Hi phillips 123
Can you post back what issue you have?
