Gmail synchronization
dobek
Hi. When gmail is trying to connect to internet it is saying "no internet connection". All other services (chrome, tweeter) are working fine.
Can you post a screenshot?
This is almost certainly not a 48 problem per se especially if your APN/internet settings are correctly configured and other internet access is working fine.
Double check your settings just to be sure:
Edit: also - any use?
http://forum.xda-developers.com/android/help/gmail-internet-connection-internet-t2981399
https://productforums.google.com/forum/#!category-topic/gmail/inbox-by-gmail-app/Jk_0n47M_gs
https://discussions.apple.com/thread/4419323
Any update?
dobek
It looks like Google app Inbox is having a problem becouse I use now old Gmail app and there is no problem. Didn't have a chance to use Inbox on different network so don't know if that's 48s problem or app itself.
Does Inbox by Gmail sync fail on wifi as well as carrier data?
If so then it's not a 48 issue.
I just installed it to try it and it syncs for me fine on both wifi and carrier data so I don't think that there's a general 48 problem here.
dobek
Inbox by Google is working fine on my wifi. Will try to get some other sim card and try other providers but it will take me some time.
