No coverage at all
niamhcarrig123
Activated sim baught membership and credit, new number and still says ive no credit. Have teyed registering to network but wont work randomely says "refreshing sim data" every now and again?
6 REPLIES 6
Can you try the SIM in another unlocked phone just to rule that out?
If not then you may need to contact 48 support:
niamhcarrig123
Ive no other unlocked phone, i think it may be my phone or where i am situated may have bo coverage because when i try to register on the network it says registering but then after a minute or 2 says cannot register try again later or else says its registered but atill doesnr work
There's always a possibility that there are outages due to the ongoing storm.
Probably best to contact 48 support to see if they can advise.
Did you get this sorted?
niamhcarrig123
Waiting until i get back to my own house to see if itll work there, supposedly its impossible to get 48 coverage where my parent live
Did you contact 48 support as I suggested?
