01-08-2013 07:07 PM
Hi, I have an android note smartphone, and Im wondering if there are specific settings to get the data to work... cos the general ones dont seem to ! any suggestions would be grrreat 😄
01-08-2013 07:25 PM
Yes - you need to configure the APN/MMS settings.
See this thread:
If your specific phone is not listed then try the Tweakker APN app:
or just use a similar phone as a guide.
Obviously you need a membership or add-on that gives data access as well.
01-08-2013 07:25 PM
See this thread:
