Can't top up
decs77
Hi my card still won't work and is not stopped by my bank. What do I do?
What happens?
If you using the app then maybe try the website.
If you're using the website then maybe try another device/browser.
If it still doesn't work they you probably need to contact 48 suport for advice:
In the meantime you could topup by voucher:
How do I top up? Overview of the top-up payment op..
