internet
clairemg
Hi, my internet has stopped working and I have over 1gb left and have turned my phone off and on and tried the same with the flight mode..can you help please?
Was there any software update on your phone?
Are the settings still correct?
http://community.48months.ie/t5/Need-Help/nexus-5/m-p/33205#M11511
You seem to be using a Samsung phone and it seems that these can sometimes spontaneously lose the APN/internet settings and need reconfiguration for some reason.
If you can't get it working then you'll probably need to contact 48 support:
