Can't recieve calls
beckyuyiosa1
I cant receive calls anymore although i could before, ive never bought membership before but i dont kmow whether thats the problem or not
You never bought membership at all?
I'm curious - why not?
When did you activate your SIM and start using it?
If it's several months ago then perhaps your account has been suspended/cancelled because it is deemed inactive?
Can you log into your online account?
I just joined it last week I have no coverage at my home at all it just reads not regesterd to network,so I can't receive or make calls
Power off, clean the SIM contacts gently, reseat it and power on again.
Any help?
If not can you do a manual search for networks and check what networks you can see?
If you can see 48 can you connect to it?
Has anything changed on the phone - e.g. software update?
If you are still having problems try putting a small amount of cash credit (at least 25c) on your account as it may be needed in order to activate the iPhone on the network. This may take a few hours and may require a sync with iTunes.
Do you have membership now?
You will need membership in order to be able to send texts or make calls etc.
