Any issues with an iPhone from the US on 48?
stevieb
Hi,
Looking at possibly getting an iPhone 6 brought back from the States - just wondering if there are any issues with using it on the 48 network, or will it be fine to use straight from the box? (factory unlocked from an apple store of course).
Thanks!
Any use?
http://www.boards.ie/vbulletin/showthread.php?t=2055508399
It's not bang up to date but if you search further your may fine a similar guide that is more up to date.
I bought an Iphone 6 recently in NYC Apple store. It was unlocked to the Verizon network and when i came home i popped my 48months sim card in and it worked 100%. Delighted with it.
There is very limited stock in the shops and by 11am- there were none left so I would advise getting there early.
nice tip goodtwin123!
I remember wanting to get a Sidekick Slide from the US years ago, but the network (CDMA vs GSM) wasnt compatible or something... nice to hear the same isnt applicable to the iPhone.
