48 won't let me buy my plan?
Any use?
http://community.48months.ie/t5/Need-Help/Can-t-topup-membership/m-p/18027#M5273
Can you tell !eif you are attempting this through Debit card or credit card, if you've successfully used the method before, and the error displayed...also what is your !membership status?
Any use?
