12-02-2021 04:55 PM
I have just put my new SIM card into my iPad, it asked to update settings which I did. Since then, it has been trying to connect but with no luck. Does anyone have any idea as to why this may be? Any suggestions gratefully received.
14-02-2021 05:42 PM
VOILÀ - I changed the settings from Local Home Profile to International Roaming and it works. Thank you folks for your time and help. 961F984E-C14C-42BA-A96A-59A10417E922.png
14-02-2021 02:28 PM
14-02-2021 02:58 PM
Hi dalyer, the Sim worked perfectly in my iPhone. I could access APN and insert the 48months thing. Got onto web etcCB5C7365-A5FE-4F56-A9C0-7F26AA442AAA.png
14-02-2021 04:00 PM
14-02-2021 04:14 PM
14-02-2021 05:15 PM
Dalyer, good point. I redid the iPhone and turned off the WiFi. I tried the APN settings you suggested and the settings Conor suggested and nothing. FC414A80-1318-46D1-9342-618D13466FB1.png
14-02-2021 05:35 PM
I put the SIM card back into the iPad and this time I actually got a signal although there is no mobile data. I was able to input the APN details that dalyer suggested and the settings Conor suggested but still nothing DE547029-54C2-4E91-A969-EEA6749B682C.png
14-02-2021 05:42 PM
14-02-2021 07:07 PM
15-02-2021 06:41 AM
15-02-2021 11:43 AM
