Auto-renewal of Membership does not work...
DenisB6311
Hi.  I joined 48, 3-4 months ago, after having been with Three for 11+ years.  From the get-go, I have had Auto-renewal of Memberships activated, but only for the 1st month has this worked - below's a screen-grab of what I've been confronted with for the past 2 months.
Basically, I'm being told that "...something went wrong..." when it tries auto-renewing my membership, and that I must go to 48's web-site and renew it manually.  What is really infuriating about this, is that 48 will not let me access any web-site - INCLUDING 48's SITE - through the 48 sim when the Membership expires!!!  My only recourse has been to go without internet until i can log onto the 48 web-site through a public 'hotspot' at work.  Not only is this very inconvenient, there are the obvious security implications of having to login over a public internet connection.
Having spent more than a decade with Three, I know first-hand that Three will allow you to access their web-site 'to fix things' if you run out of credit, so I'm at a loss as to why 48, an offshoot of Three, will not allow the same.  To say I find this shortsighted is an understatement.
Has anyone else experienced this, and if so, how do I go about getting 48 to fix it?  Thanks,
48's Broken Memberships.48's Broken Memberships.
Try support@48months.zendesk.com or log a support ticket.
Hope this helps
12 REPLIES 12
I got the same issue twice. First time in March and again in June.
I had to renew manually and turn on again auto-renew.
I think the minimum thing 48 should try automatically if it gets fail after few hours.
Otherwise, we will discover it during a moment that we are unable to access the internet preventing us to perform this renew.
Fredh6195
Have set auto renew each time I buy membership and it tells me near the end of the membership it will renew automatically but then it says I have not renewed and have to try several times to get new membership.
Have either/both of your tried to resolve this with 48 support?
If so what did they say about it?
