my 48 will not allow me to make phone calls message mobile
EamonnF7806
Your post was blank @EamonnF7806 and the subject line doesn't really clarify your query.
If you want assistance from the Community Forum then you need to explain/describe your issue or question clearly.
When was it working ok last?
If not then if you do a manual search for networks can you see and connect to 58?
If not then are you sure that your phone is unlocked for use on any network?
If you do get a network connection then...
Can you receive calls/texts or use mobile data?
What happens when you try to make a call or send a text?
Any error messages?
