Internet connection weak showing waiting connection
SheilaD0403
connecting always waiting forvthe network very slow poor connection
Your post is a bit garbled and confusing.
What exactly do you mean by "connecting always waiting forvthe network"?
Describe exactly what you are doing, what happens, any error messages etc.
When was mobile data working OK for you last?
What changed in the meantime?
E.g. phone software update, settings changes, factory reset/restore, new handset, returned from roaming abroad, etc.?
If you are having problems with the 48 mobile data connection/speed then the first thing to check is that your APN settings are configured correctly.
See here:
If you have an Android device then text "APN" to 50048 and follow the instructions here to configure the APN settings correctly:
If you still have problems when the APN settings are configured correctly then you may need to try a replacement SIM:
Are calls and texts working OK?
