INTERENT PROBLEMS!
stevepratt89
Recently I switched to 48 months and I have found that my WhatsApp messages in particular and other apps while out of Wi-Fi access take a long period to deliver and my phone coverage would still be good. I have followed your advise on tweaking my internet settings and still find no improvement. Please help.
7 REPLIES 7
When you are not connected to wifi (e.g. out of range of a wifi LAN or wifi switched off) does internet access work ok?
E.g. browsing the web etc.?
Somebody else reported this recently and the problem was simply that their internet settings were wrong so WhatsApp messages were only getting sent/received when they were back in range of a wifi LAN connection.
Any update @stevepratt89?
stevepratt89
I've followed the instructions here and used the 48 months internet tweaking installation and still no improvement on any of the apps. What's app messages still take forever to send and receive
stevepratt89
That other person the reported the same problem recently was my girlfriend. I've tried copying her settings for the APN and the 48 tweaking and still no joy
You didn't clarify if regular internet access works ok while out and about and not connected to a wifi LAN.
I'd suggest that your start again, delete any apn settings that you have and use these instructions to configure your settings properly.
http://community.48months.ie/t5/The-Knowledgebase/My-Internet-is-not-working/ta-p/45928
If you do that and regular internet access works while out and about but WhatsApp is still slow to send/receive then you may need to contact WhatsApp as it doesn't sound like a 48 issue.
Did that help at all @stevepratt89?
