Seeking eSIM for iPhone 15
VitalinaS1886
Good afternoon! I can’t transfer my phone to a new phone. I have a physical SIM card, I need to convert it to a virtual one. since the 15 Pro Mac does not have a SIM card slot. can you help, you need to try through the QR code.
48 don't support eSIMs.
European iPhone 15 handsets should still have a physical SIM tray.
If you have a US model with no physical SIM tray then you won't be able to use it on 48 for the moment.
