Roaming not working - what to do?
TamaraN6032
Hi,
My roaming is working. Can you pls advise what should I do ?
Should I order new sim roaming card ?
Thank you
Tamara
TamaraN6032
Is not working
You don't clarify what country/region you're roaming in and what the specifics of your problems are.
As such, the only option is to reiterate the usual generic advice regarding roaming...
