Roaming won't work
rhona03
I'm in Lanzarote roaming won't work
What happens?
No signal/network connection at all?
Nothing works - calls, texts, data?
What if you do a manual search for networks?
Can you see any local network and connect to it?
If it's an iPhone then you might need to try this:
https://community.48months.ie/t5/Most-Popular-Questions/iPhone-abroad-issue/td-p/36862
Any update @rhona03 ?
