Phone use abroad
Alisonr9895
Hi my daughter is in Croatia and it’s saying she is out of data, when I went onto app to top her up it said she’s 18days left so o can’t top her up
What exactly do you mean by "top her up"?
What exactly were you/she trying to buy?
Monthly membership plan, cash credit, add-on?
If she has used up her EU roaming data allowance then she needs to buy a mobile data add-on.
See here:
Can I buy extra Data for EU/UK roaming?
Yes! If you've used your EU/UK data roaming allowance or simply just want more, then the 1GB data add-on can be used in Ireland and in the EU/UK when you’re on a plan that has roaming included. To purchase your add on, simply Log in to your My48 >> Flexi Data >> Add ons, or just click here.
