50m ago
46m ago - last edited 45m ago
If you want assistance from the Community Forum then you'll need to provide a bit more information and context than that.
You say that the phone didn't ring but does the call connect and call you answer it?
When were incoming calls work ok last?
What changed in the meantime?
Are all incoming calls affected or only some.
If only some then is there anything common between the affected callers/numbers/providers?
What happens at their end when they call and it doesn't connect?
Any error messages?
Are outgoing calls working ok?
Including to numbers that can't connect calls to your number?
Are incoming/outgoing texts working ok?
Is mobile data working ok?
Can you try your SIM in another unlocked phone (and maybe an Android rather than iPhone) to see if the calls work there?
