16m ago
8m ago - last edited 2m ago
What do you mean by "I paid €10 for my plan"?
There's no monthly membership plan that costs €10.
What exactly did you buy/pay for?
What does your Transactions page say about your recent payment?
If it was cash credit rather than a membership plan that you bought then you should probably read this to understand the difference between the two:
Do you have an active membership plan listed on your My48 account dashboard?
Does your dashboard list any cash credit balance?
When did you last successfully buy a membership plan?
When was everything working ok last?
What changed in the meantime?
What exactly are the symptoms of "my plan has been disconnected", "my plan has been completely deactivated", "My phone service is also deactivated" and "my SIM card seems to be inactive"?
Incoming/outgoing calls?
Incoming/outgoing texts?
Mobile data?
