Phone number merge
KateL9146
Phone number merge
Your post doesn't really make much sense.
What does "phone number merge" mean?
What exactly are you trying to do or asking about?
If it's how to port a number from another provider to 48 then see here:
If that's not the issue then perhaps the New to 48 FAQs have something that addresses your issue?
Otherwise you need to explain the issue/question more clearly.
