Phone not working on holidays
SheilaM5316
SheilaM5316
Help me please to get my phone working can receive calls can't ring out help please
What country are you in?
48 doesn't support roaming in every country/region.
Do you have a connection to a local network - i.e. signal bars?
If not then if you do a manual search for networks can you connect to one?
If not then what happens? Any error messages?
For roaming issues the usual general advice applies...
