an hour ago
4m ago - last edited 2m ago
You'll need to provide a bit more information than that if you want assistance from the Community Forum.
When was everything working ok last?
What changed in the meantime?
What exactly do you mean by "no signal/signal issue"?
Incoming/outgoing calls?
Incoming/outgoing texts?
Mobile data?
