Going abroad
RoisinW3765
Do I need a new sim to travel to Uk cause there not EU and roaming won’t work ?
48 support the same roaming services in the EU and UK (as well as a few other non EU counties).
There isn't a special SIM for the UK.
On the general issue of roaming, the usual generic advice applies...
