10-11-2020 10:27 AM
Hi,
I have moved to the 48 Network over a month ago. In the last 2 weeks I have noticed that most days I have no network coverage or mobile data available. My phone constantly says 'emergency calls only'. 7 of my friends & family have switched over also & most of them are experiencing the same issues.
Is anyone else having this issue, or could it be that there is just no coverage where we live. Would I be better of going back to my old network? I was previously with Three & never had any coverage issues.
10-11-2020 10:31 AM
If up to eight people are having the same problem then it sounds like a coverage issue in your area.
Are you in a remote area or something?
You should contact 48 support to see if they are aware of any issues in your area.
29-01-2021 04:46 PM
29-01-2021 05:00 PM
29-01-2021 06:15 PM
29-01-2021 07:05 PM
30-01-2021 02:28 PM
I have just activated my 48 sim, seems to have no mobile data, cant make any calls either, had a 3 sim previously, worked ok...Charles
30-01-2021 03:45 PM
