Need to unlock old Nokia Tks
sharon24
Have old Nokia square block just phone need to unlock Tks
What do you mean "has code inside"?
Do you already have an unlock code?
If so just put in a 48 sim and enter the code when prompted.
If you don't have an unlock code then you need to get it unlocked in a phone shop out buy an unlock code online if possible.
You may need to know what network it's locked to in order to do this.
You mean unlock the phone for use on the 48 network?
48 can't do this for you.
You'll need to get it unlocked by the carrier to which it's locked or else unofficially online or in a phone shop.
Some phones can be unlocked for free otherwise usually for a small fee.
What model is it?
Nokia 100has code inside and imei number also Tks
Thank you very much
