My phone is not working
EmerD5260
You'll need to post a bit more info if you want assistance from the Community Forum.
What exactly is not working?
Do you have a connection to the 48 network?
Does anything work - incoming/outgoing calls/texts or mobile data?
What happens when you try to use such services - any error messages?
Did all of this ever work or are you new to 48?
If it did work before then when did you start experiencing problems and did anything change at that time - e.g. settings changes, software update, factory reset, new phone etc.?
If you are new to 48 then you might need to read the Starting With 48 FAQs:
