My iphone wont work in N.Ireland
My iphone wont work with new sim card , when I go to the Norht of Ireland. Was told this issue would be fixed with new sim that would work on romaing automatically. It hasnt and wont, so effectively dead phone every time I am in the North , has someone had similar expereince , any soultuions. The ones 48 keep asking me to do , simply do not work.  Is there another sim card company that works any suggestions
Did you try the suggestions in these threads?
What happens?
Do you get any error messages?
Does a manual scan show any NI networks?
What happens if you try to connect to them?
Nothing came up nothing worked and the team supoort was ineffectual actually they made a commevt thatcso many people are having same issues change network to something that works
You mean no networks are listed when you do a manual scan?
Did you try all of the suggestions in the linked threads?
Are you saying that 48 support suggested that you change networks? 😯
