27-11-2023 02:59 PM
27-11-2023 05:05 PM
What do you mean by "updated"?
48 don't push software updates to phones.
You need to clarify what exactly you're referring to here.
If you need to contact 48 support about this then see the link in my signature below or email them at [email protected]
27-11-2023 02:38 PM
27-11-2023 02:33 PM
27-11-2023 05:15 PM
Your post was blank @EilishC1634
You still haven't really explained what the issue is that you're experiencing.
You need to describe the issue, what the problem is, any error messages encountered etc.
As I've said several times if you need to contact 48 support about this then see the link in my signature below or email them at [email protected]
27-11-2023 02:45 PM - edited 27-11-2023 02:45 PM
What's the problem that you're experiencing?
You need to explain/describe it if you want assistance from the Community Forum.
If you need to contact 48 support then see the link in my signature below or email them at [email protected]
27-11-2023 05:07 PM
Duplicate threads merged.
