How to buy a plan using cash credit on account?
OliviaS8431
hi there
i have 13 in credit and want to buy monthly plan. How do i do this please?
Every time i try, i gives up a pay by card message.
If the cost of whatever you're trying to buy is less than or equal to the amount of cash credit on your account then you should get the option to pay using cash credit at checkout.
If you're using the app then try the website, or vice versa.
This is the web link.
If you're not getting the option to pay with cash credit then you'll need to contact 48 support for assistance.
