Hotspot
AliciaBrayK4388
Does the 10.99 membership allow us to have a personal hotspot because i cant find the option to turn it on in my settings
Yes you can use your hotspot.
The reason you can't see the option is because of the stupid way that Apple do things.
Read this in full, in particular the bit about configuring an iPhone's personal hotspot.
https://community.48.ie/t5/Other-Help/Internet-not-working-on-HUAWEI-ASCEND-g6-u10/m-p/34493/highlig...
Hi. I’m the same problem. I can’t see the option to share data. I have a iPhone 12 Pro Max. How can I do? Thanks!
See here - in particular the section titled "A note about personal hotspot setup on iPhones"
If that doesn't help then you'll probably need to contact 48 support for further assistance.
