48.ie failure
JosephG0091
48.ie won't work when roaming
What exactly do you mean by this?
  • 48.ie won't work when roaming
Do you mean that you can't access the 48.ie website?
Can you access other websites?
Or do you mean that something else isn't working while roaming?
What services exactly?
Incoming/outgoing calls?
Incoming/outgoing texts?
Mobile data?
What country are you roaming in?
On the general issue of roaming, the usual generic advice applies...
JosephG0091
My wife and I just returned from Spain and 48.ie just didn't work
You never responded to my reply to your original post that attempted to clarify the exact nature of your issue:
