Emigrating, need to unlock phone.
PierceD3697
I am moving to Australia. I will need to switch to a new mobile service. How do I unlock my phone from 48?
A phone cannot be locked to 48.
Why do you think that your phone is?
48 actually requires a phone that is not locked to any network and is SIM free.
https://48.ie/unlock-your-phone
If you just mean how do you leave 48 and use the phone on another network then all you need to do is disable membership auto-renewal (if enabled), delete your registered card details (if applicable) and then use the phone elsewhere.
PierceD3697
Thank you Dalyer.
You're welcome.
