Unlocking my phone with my pin
EvelynG4548
I have tried to enter in what I thought was my pin to unlock my phone but unfortunately this has not worked. And I am locked out of my phone.
I need help with this.
Can you please contact me? Or is there a customer service number that i can use?
Thanks
Evelyn
Sounds like you may need your PUK to unlock the phone now?
See here:
If that's not the issue then please clarify what is.
If you want to disable SIM PIN locking then see here:
