Anyone else having trouble with calls/texts on 48?
LouiseM3881
Hey is anyone having trouble making call or texts with 48??
You'll need to post a bit more information than that if you want assistance from the Community Forum.
When was it working ok for you last?
Did anything change since then - phone software update, settings changes, factory reset, new phone, returned from roaming abroad, etc.?
Could Storm Darragh have knocked out services locally?
Are any services working? Calls/texts/mobile data?
If you can't make calls or send texts can you receive calls/texts?
