Roaming didn't work in Rome last week (and on other trips)
tishie
I just put in a new sim before travelling to Rome last week but once again I had no roaming.  I have followed the trouble shooting guide but no luck.  I have never managed to get roaming despite following the guide and changing the sim twice.  What is the problem.  I really do need to sort this out or will be forced to change provider.
Perhaps it coincided with this seemingly general problem with roaming last week?
However, even when there isn't such a widespread outage unfortunately many people still seem to have problems when trying to use roaming services for some reason and nobody from 48 has ever explained why or provided a guaranteed fix.
This is not satisfactory.  I have changed my sim twice and still never managed to get roaming either in NI or mainland Europe.  I couldn't recommend 48.ie only works when in 26 counties.
You'll have to take that up with 48 support so.
