Activate number is not working
PaulC9171
Please enter valid activation code
PaulC9171
The code i got doesn't work, it live till the 20th November
You post is confusing.
Can you explain what precisely the problem is that you're facing?
PaulC9171
If the activation code does not work then see here:
https://community.48.ie/t5/The-Knowledgebase/Getting-Started-How-to-Activate-your-48-SIM/ta-p/53099
