when i in holidays(spain) can i use roaming text ?
grazina
Yes.
You can either buy the EU roaming text add-on (35 texts for €2 or 5.7c per text) or just pay for outgoing texts from your credit balance (7c per text).
If you plan on making or receiving calls the EU roaming calls add-on may be worth looking at particularly because it means that incoming calls are free.
If you're using an iPhone then note this as it may be relevant when you start roaming abroad:
grazina
Thanks for help i get the answer
grazina
Thanks for help i get the answer!!!
