warning fair usage
thekiddy
Got a warning to say im reaching my fair usage limit ???????? And I be suspended
What's the question?
The terms & conditions of 48 membership include a fair usage clause:
If it's just a warning then you are presumably not barred but may be if you breach the relevant limits. If you do get barred it's for the remainder of your current membership month after which you need to contact 48 support to get reinstated.
If you get barred for a second time then it's for good.
How long is left on your current membership? You might want to ease up on calls/texts to avoid breaching the limits and getting barred?
