security code
Hi all. I amtrying to register my 48 SIM. When I request a security code i am getting in green writing Oops! You got an error! Could not request a port in code. Try again in few minutes. Can anyone assist.
I presume that you are trying to register the SIM and port your old number over at the same time?
Are you sure that you are entering the correct data into the form(s?)?
Another option is to register the SIM and get a new 089 number first and once the SIM is registered and up and running port your old number separately:
How do I keep my old number?
Bear in mind that number porting does not happen 24x7 (from the link above):
*** Please note: Number transfer hours are 8am to 6pm Mon to Fri, 10am to 4pm Sat and Sun.
If none of this helps then log a support request to get 48 support to assist you:
