roaming allowance and add ons
Aidand9867
Hey,im wondering if its possible to add some additional roaming data allowance after you used up?
Yes, you can buy a data add-on and use it while roaming abroad.
https://community.48.ie/t5/The-Knowledgebase/Roaming-Using-your-phone-abroad/ta-p/53115
Can I buy extra Data for EU/UK roaming?
Yes! If you've used your EU/UK data roaming allowance or simply just want more then the 1GB data add-on can be used in Ireland and in the EU/UK when you’re on a membership that has roaming included. To purchase your add on simply Log in to your My48 >> Flexi Data >> Add ons or just click here
