Search instead for
Do you mean
Reply
Highlighted
Accepted Solution
ring time
‎07-12-2013 11:04 PM
Hi lads I have a iphone 4 that I need to increase ring time as it only ring for 10 seconds can you help please?cheers bryer.
Reply
Accepted Solutions
Highlighted
Re: ring time
[ Edited ]
‎08-12-2013 10:55 AM
Hi!
Good query!
Give this below a shot...
Change the length of your phone's ringing time and avoid missing that important call. You increase the time from 5 to 30 seconds, or in mulitples of 5 seconds. Just type the following code into your phone: **61*(mailbox number)**(number of seconds you want it to ring for)#send The standard ringing time is 15 seconds. If you don't know your mailbox number it's just your normal mobile number with '5' added after the prefix. For example, 087 5 1234567.
I think this should work!
Post back when your done & can you tell us if it has in fact, extended you ring-time.
Posted from Samsung GT-I9100
Reply
All Replies
Highlighted
Re: ring time
[ Edited ]
Hi!
Good query!
Reply
Highlighted
Re: ring time
‎08-12-2013 12:01 PM
Top man  worked 10 out of 10 cheers.
Reply
Highlighted
Re: ring time
‎08-12-2013 12:02 PM
Glad your sorted...
Any further queries, post us in the forum, we'll try to help if we can!
Reply
Highlighted
Re: ring time
‎26-12-2013 02:49 PM
My phone is telling me not registered on network what can i do please
Reply
Highlighted
Re: ring time
‎26-12-2013 03:53 PM
Have you Registered with 48?
See the link below:
http://community.48months.ie/t5/Most-Popular-Questions-Knowledge/How-to-register-your-48-SIM/ta-p/23...
If you have Registered,you may need to manually select 48 on you handsets Network Settings.
Perhaps a quick look of your my 48 page might enlighten you to the reason for error message if you have no success with the suggestions listed above.
Smiley Happy
Reply
Highlighted
Re: ring time
[ Edited ]
‎21-01-2014 01:24 PM
Reply
Highlighted
Re: ring time
‎21-01-2014 02:07 PM
Hi karlmarcks
Your post was blank... have you a query?
Reply
Announcements
Welcome to the 48Community!
Order a free SIM
Unlock your phone
Ask the community
