problem sending text messages
Hi I've my membership paid up and my sms centre number is +353894300000. I can send texts but I can't receive them. Saw a question about this but the link attached to go to crew is now invalid. Don't know what to do 😞
Any chance your message storage space is full?
Can you delete some messages and see if that helps?
Does the sender of a text get any error message when you don't get it?
If necessary contact 48 support about this:
shkyboy
How can I send a text to 5 digit numbers like 53104 etc?
Unfortunately you can't.
48 don't support sending text messages to premium SMS 5XXXX numbers.
AdrianH5605
I had teh same issue when I ported, enter this code at the keypad and it should work -- **5005*7672*+353894300000#
(It sets the correct SMS-Center)
That's got going to change the fact that on 48 you can't sent messages to premium SMS (5xxxx) numbers.
