pin locked.
gerryh2
Phone is unlocked.but when I turn it on or
Restart it error message comes up sim locked.i then put in sim pin and it works fine.any ideas .
gerryh2
Hi ,
Thank You for your help.your answer was perfect .I turned off sim pin and now it works
perfectly.
Thank You again.
Sounds like it's simply a case of SIM PIN locking being enabled rather than anything to do with the phone being locked to a particular network?
You seem to be using an Android phone?
If so then SIM PIN locking is normally controlled under something like System settings > Security > Set up SIM card lock  etc.
gerryh2
Hi ,
perfectly.
Thank You again.
Great - glad it helped.
